Thread: How many straps do you use to tie down your motorcycle?
Created on: 06/03/18 06:29 PM
morgstang
morgstang's Gravatar
06/03/18 6:29 PM
Ive heard a number of stories of people having bikes fall over if a strap breaks from only using 2...ive always used 4 to make sure its safely secured...BUT there could be an instance of 2 straps breaking on the same side i guess...lol
"King of Clean"
RE: How many straps do you use to tie down your motorcycle?
06/03/18 10:27 PM
5 straps. I run 2 at the bars/lower forks with the soft straps. 2 at the back. 1 wrapped at the front wheel so it does not flop over on the fork stop. say the straps stretch loose. That's the trick... make the front wheel stationary so it can't walk.
Nastynotch
Nastynotch's Gravatar
06/04/18 5:02 AM
I run 8 straps. I double up each corner just in case one decides to fail. Overkill maybe but it doesn’t hurt to have the peace of mind.
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
06/04/18 7:50 AM
A minimum of 4 good quality straps.
C14
C14's Gravatar
06/04/18 6:42 PM
Trailer?
06/04/18 9:27 PM
About 10! I have 4 main, good strong straps: 1 to each canyon cage across the grips and 1 to each passenger peg / exhaust hanger bracket, all 4 pulling forward and downward, with the front wheel in a chock. Then, since I have a bin of various bungees I add several of them to each side of the bike ... kinda until I'm tired of applying and/or the bike no longer moves! My goal is to make it so that if any strap breaks, although the bike may move a little it won't fall over. I hope I'll notice its movement in my mirror and be able to stop to re-secure it before something else fails.
* Last updated by: extrapolator on 6/13/2018 @ 1:29 PM *
06/05/18 8:59 AM
0
I'm planning on getting Pit Bull trailer restraints. Maybe one for each bike.
They cost quite a bit more than straps but there's no way the bike will tip over.
They look awful darned cool too.
* Last updated by: Rook on 6/5/2018 @ 9:00 AM *
Badzx14r
Badzx14r's Gravatar
06/05/18 3:28 PM
What are straps ?
06/05/18 4:28 PM
Maybe you're joking, but if not ... Ratchet straps:
RBRBBB
06/08/18 10:45 AM
I've hauled a lot of bikes through the years. I use 4 straps, 2 in front pulling to front and side, 2 in rear pulling rearward and to the sides. Buddy has a large Harley and did use 4 in the front for that one. Use double loop strap wraps at all four mounts for a tighter grip on the bike and less chaffing to the motorcycle. Make sure you eliminate all excess straps flapping in the wind, can do a lot of damage by the time you get to your destination.
Does anyone know if it harms the fork seals having the front fork compressed for an extended period of time?
RBRBBB
06/08/18 10:47 AM
I've hauled a lot of bikes through the years. I use 4 straps, 2 in front pulling to front and side, 2 in rear pulling rearward and to the sides. Buddy has a large Harley and did use 4 in the front for that one. Use double loop strap wraps at all four mounts for a tighter grip on the bike and less chaffing to the motorcycle. Make sure you eliminate all excess straps flapping in the wind, can do a lot of damage by the time you get to your destination. Another heavier ratchet down on the trailer and the end with just the hook on the motorcycle end.
06/08/18 4:42 PM
I use "3" straps.
I don't like compressing my suspension.
I use the Cycle Cynch II (like Canyon Dancers) on the front.
Only snug enough to balance/pull bike forward.
Then I use the rubber keepers(below) on the tie down hooks so the hooks
don't come undone if you hit a bump.
For the rear I use a single heavy duty ratchet strap.
Secure one end, pass through rim and around tire and secure end, ratchet down
good and tight.
RBRBBB
06/13/18 12:47 PM
piken, never seen the rubber keepers before. Might buy some.
RRZX14
RRZX14's Gravatar
06/24/18 4:06 PM
5 usually, one on each clip-on, one on each passenger peg bracket, and one going over the passenger seat for a extra piece of mind.
Red 2006, butterfly valves pulled, otherwise stock.
"She rolled out of bed, hopped on her menstrual cycle and ran my ass over." - Walter
"If you want to be a lumberjack, you have to learn to handle your end of the log." - Harry Callahan
"He that would live in peace and at ease must not speak all he knows or all he sees." - Benjamin Franklin
nkd
nkd's Gravatar
06/29/18 10:49 AM
I use 2 or 3 straps. One custom strap on the rear and 1 or 2 on the front. The front strap is not needed to hold the bike sturdy but who knows if you are on a rough road or in an emergency maneuver. Prefer 2 on the front axle as not to mark the paint on the rims. never had a problem. No picture of my 14R but here are some of my 12R and a friends.
* Last updated by: nkd on 6/29/2018 @ 10:49 AM *
06/29/18 11:31 AM
Just realized, the front could actual be secured using a rod thru the front axle ... similar to the rod I'm using here, but maybe threaded, and maybe with hooks on the ends:
Danno's Gravatar
Southwestern Illinois
07/29/18 10:50 AM
2 for short hauls
4 for long distance
I slways use a front wheel chock
Loop soft ties make tying down easier and make scuffs and damage less likely.
07/29/18 1:10 PM
doubleD
doubleD's Gravatar
07/29/18 2:43 PM
I watched our fellow Concours C14 riders use the hollow axles for tie-down locations.
ominousone
Twin Cites So Burbs, MN
08/20/18 6:55 AM
What do you guys recommend, Canyon Dancer II, or PowerTrye Handlebar Handcuffs? For my 2016 ZX14R SE ABS.
Thanks,
ominousone
08/20/18 8:03 AM
What the?? You mean Kawi's sport touring model? Why aren't they riding there?!
ominousone
08/25/18 9:21 AM
Where do you find those rubber keepers and how do they work?
ominousone
08/25/18 10:18 AM
here...
keepers
* Last updated by: piken on 8/25/2018 @ 10:19 AM *
ominousone
08/25/18 10:37 AM
Thanks piken. So these would work on the Ancra, or equal tie downs?
ominousone
GGBrown
GGBrown's Gravatar
09/13/18 4:45 PM
4 Straps and I will only use a U-Haul Motorcycle Trailer ($25.00)
55 & still feeling the need for speed.
